Replacing engine
120,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
LUAY
Hello dears, I have a problem with car consumption, I am thinking of changing the engine to 1.8L, is it recommended, and if yes, what other parts I need to change with the engine?
Sep 23, 2019 at 5:19 AM
  • 55,694 POSTS
The best thing to do is call a wrecking yard to see if that engine is interchangeable they have special software that tells what you need if I were to guess I say the engine and computer with the main engine wiring harness. I'm not sure if the transmission will bolt up as well. Let me know what happens.
Sep 24, 2019 at 6:04 AM
