Got the classic "no horn or cruise control, and air bag light on" symptoms that point to a bad clock spring. I've researched the job and bought the part but have some concerns about the danger of the airbag activating while it's upside down on the steering column. I know I need to disconnect the battery and give it time to discharge the entire system. I read that even a little static electricity can trigger it. Am I over-worried, is there a way to ensure it won't go off, or is this job best left to the pros? Side question: If I want to temporarily re-route the horn wiring to a push button on the dash (to pass PA safety inspection) until I can get the clock spring replaced, any idea which wires I'd need to grab under the dash? Thanks, a heap!
Aug 14, 2024 at 3:10 AM
