Replacing Cam and Lifters?
60,000 MILES • 6.2L
YASICK
Having a difficult time finding all the torque specifications needed for reassembly. Cam phaser bolt oil pump bolts, cylinder head bolts, rocker arm bolts.
Dec 29, 2022 at 11:13 AM
  • 110,246 POSTS
The torque specs are listed based on components. For example, cylinder heads, rod bearings, and so on.
If you look below, I attached a few pics. They are the torque specs for everything on the engine. Take a look through them and let me know if there is anything missing that you need.
Also, pay attention to some. They are listed in inch-pounds and not foot-pounds.
Let me know if this helps.
joe
See pics below. Note: The first 4 pics are for the valve covers.
Dec 29, 2022 at 4:06 PM
