Replacing burnt lights on the cluster
150,000 MILES • 3.5L • V6 • AUTOMATIC
EBALLESTEROS
  • 9 POSTS
I pretty well know the procedure to get the cluster out. My question relates mostly about to know if once I remove the cluster and put it back in place (after replacing the bulbs), Is there any thing that has to be reprogrammed?
Thanks,
Eduardo
Sep 8, 2017 at 8:57 AM
  • 55,688 POSTS
No, you should be good. make sure the key is off and the battery disconnected before you begin.
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Sep 9, 2017 at 10:34 AM
EBALLESTEROS
  • 9 POSTS
Thanks a lot Ken, really appreciate it.
Will let you know how it went, after I do it, It will not be right away but I will do it ASAP.
Thanks again!
Eduardo
Sep 11, 2017 at 3:02 AM
  • 55,688 POSTS
Please let us know what happens and upload pictures of the problem.
Cheers, Ken
Sep 11, 2017 at 4:22 AM
