Replacing brake calipers
98,000 MILES • 3.1L • 2WD • AUTOMATIC
BLAKE WOELFEL
I replaced the rotor, and the pads. I can fit the caliper over the rotor and get one screw to go in and tighten, but the other starts to go in almost to the threads and won't go any further. It doesn't matter which one. Top or bottom, one always stops just before the threads so I can get both tightened.
Oct 18, 2020 at 3:24 PM
Good morning,
It sounds like the calipers are not fully seated correctly. The pistons may not be fully retracted not allowing the caliper to seat correctly.
Can you post some pictures of what you see? I attached some guides for you of the replacement of the pads, rotors and calipers.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
https://www.2carpros.com/articles/brake-caliper-replacement
Mar 29, 2021 at 6:47 AM
BLAKE WOELFEL
Thanks for the reply and the help. Here are some pictures.
As I suspected, the caliper piston is not fully retracted. The pistons need to e all the way in.
Then the pad will rest against the caliper and then it will fit over the rotor.
BLAKE WOELFEL
Thank you. I'll push them in further.
You are welcome.
Always glad to help.
