Replacing Ash Tray?
106,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
PARKS09
I see yall have worked on the radio and USB in the dash area of the 2005 F150. The ash tray is broken in mine and I want to replace it with a cubby storage bin or just cover the hole up. I can't seem to find the right part to fit this area. Have you all had experience with doing away with the ash tray in these trucks?
Thanks
Nov 5, 2025 at 11:16 PM
  • 55,579 POSTS
O ya, you need to push down the center tab with the ash try open to remove the try, then remove the two mounting screws for the hosing which you can get to once the try itself has been removed to remove the housing/track. Upload images for any question you have so I can see it.
Nov 9, 2025 at 2:02 AM
PARKS09
I know how to remove it. I am inquiring about replacing it with a cubby storage bin or an ash tray delete.
Nov 13, 2025 at 3:59 AM
  • 55,579 POSTS
It should just bolt it, I don't understand what the problem is, can you upload a short video? You can do so in your response.
Nov 15, 2025 at 12:32 AM
