Replacing ABS Control Module, does it need to be programmed?
64,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MIKE GILMOUR
If I change out the ABS control module myself, does it need to be programmed or will it work okay by me just changing the module? The computer code read out said “control module inner failure”. I can change out the module myself if that is all that is needed.
Jul 24, 2023 at 8:25 AM
STEVE W.
  • 15,418 POSTS
Yes, the module needs to be accessed prior to removal with a scan tool so the configuration file can be copied to the tool, then you replace the module and connect to the replacement and upload the configuration file into it. This is because Ford uses the file to tell the module the vehicle information, things like engine, transmission, tire size and more. In your case where it says inner failure, the module may not allow the file to be copied from it and in that case, you use a dealer portal or the Ford tech line with your VIN to download the proper file into the module.
Changing the electronics itself isn't that bad, Remove the shielding and unplug it, remove the screws and drop the module. Reverse the process to install the new one and upload the configuration file. Done.
Jul 25, 2023 at 10:37 AM
