need to know how to replace ABS valve and computer at same time? And how to bleed system?
Dec 8, 2017 at 11:24 PM
WRENCHTECH
✓Experienced Mechanic
Replacing the parts is pretty straight forward. The lines are threaded and the parts bolt together but you are not going to be able to bleed this system yourself without a high end, enhanced scan tool. It has to be electronically bled with the scan tool.
