Replacement of timing drive components
174,000 MILES • 6 CYL • 4WD • AUTOMATIC
GUESTWIFIUSER
I removed the LH hydraulic chain tensioner easily and it is not going in smoothly the way it came out. I think the plastic guide is in the way and restricts the rest threading or screwing in place. What do you advice?
Mar 4, 2016 at 10:20 PM
  • 55,743 POSTS
This is a big problem with Ford engines, hit the pin with some WD 40 and wait it out for a bit, then with a small butane torch heat the area around the pin this should help loosen the pin and free the rust.
Mar 11, 2016 at 12:22 PM
  • 55,743 POSTS
Let me know how it goes
Mar 11, 2016 at 12:23 PM
