transmission Replacement
6,300 MILES • 3.7L • V6 • RWD
GERMANG
Hello my name is German. I need a really good professional advise very urgent please! I leased 370Z 2016 around six months ago. A few weeks ago I found a little weird sound kind of whistling under the car in the middle section. Dealership said that they will replace transmission assembly and concentric slave cylinder unit. Can I request a new car from them. After six months a very significant and expensive replacement is not good for the car.
Thank you!
May 13, 2016 at 7:51 AM
CARADIODOC
  • 34,414 POSTS
Most problems occur within the first few months. That is what the warranty is for. Requesting a different car is not realistic. You should be grateful the dealer has stepped up and is willing to take care of the problem. You are just as likely to have a problem that requires attention with a different car too.
May 13, 2016 at 7:55 AM
