Replacement of A/C compressor control valve
195,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
DAVID MALANIA
  • 14 POSTS
Good day,
To replace compressor control valve, is it necessary to remove compressor and discharge Freon from system? or it can be replaced in situ?
Jun 24, 2020 at 3:54 AM
Good afternoon,
Compressor control valve? Can you please explain?
Do you mean the expansion valve?
Jun 24, 2020 at 4:16 AM
Do you think you can be a little more descriptive as to what the control valve is that you are referring too? I assume you are talking about the compressor clutch?
I put a picture of the compressor to try and figure this out. The issue I am having is we don't have a component that is part of the compressor called the control valve so I am hoping we can figure out the part that you are going for and we will figure this out. Thanks
Jun 24, 2020 at 4:19 AM
DAVID MALANIA
  • 14 POSTS
Good afternoon,
I have add pictures, hope shown clearly what valve I mean.
Jun 24, 2020 at 4:37 AM
Thanks. Yes, the compressor must be removed for this procedure.
if you are going to do this, make sure you use 1,000 volt gloves to disable the Hybrid system.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
How was it determined that this was the issue?
Removal and Installation
CAUTION: If installing a new A/C compressor due to an internal failure of the old unit, carry out the following procedures to remove contamination from the A/C system. Failure to remove contamination from the A/C system, if present, will result in poor A/C performance and/or damage to the new A/C compressor and other components.
If A/C flushing equipment is available, carry out flushing of the A/C system prior to installing a new A/C compressor.
If A/C flushing equipment is not available, carry out filtering of the A/C system after a new A/C compressor has been installed.
Install a new thermostatic expansion valve (TXV), as directed by the A/C flushing or filtering procedure.
Install a new auxiliary TXV, as directed by the A/C flushing or filtering procedure.
Install a new passenger zone valve.
Install a new battery zone valve.
Install a new receiver/drier as directed by the A/C flushing or filtering procedure.
NOTE:
Installation of a new receiver/drier is not required when repairing the A/C system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the receiver/drier.
If installing a new A/C compressor, the A/C clutch disc and hub, A/C compressor pulley and A/C clutch field coil must be inspected and transferred from the old unit to the new unit if suitable for reuse.
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Recover the refrigerant.
3. Remove the RH lower engine splash shield.
Jun 24, 2020 at 4:49 AM
DAVID MALANIA
  • 14 POSTS
Many thanks Roy,
2CarPros is the best site.
Regarding your question "How was it determined"? : - just my friend's conditioner had the same symptoms as mine, he had changed this valve and now all is in order, that is why I decided to do the same.
Jun 24, 2020 at 5:08 AM
Okay, good luck. I hope it works out for you.
You are welcome.
Always glad to help.
Jun 24, 2020 at 5:15 AM
