Replacement distributor
200,000 MILES • V8 • 2WD • AUTOMATIC
SPRSPR
I have the truck listed above. It had a blown 305, replacing with a 350 but want single wire (non computer controlled) distributor. What year of distributor would work and should spark plug match year of distributor or year of engine?
Mar 20, 2018 at 5:58 AM
CARADIODOC
  • 34,414 POSTS
Spark plugs are specific to the engine. It does not matter what generates the spark voltage.
1984 was the first year for GM's High Energy Ignition, (HEI) system. The camshaft gear stayed the same so the distributor was a drop-in replacement, but there is a dropping resistor in your truck's wiring that is needed with breaker points but not with the HEI distributor. That resistor could be a white ceramic ballast resistor, about 2 1/2 inches long and 3/4" square, or it could be a resistance wire that is part of the wiring harness. That has to be removed.
1986 was a changeover year where both the old-style and new-style distributors were used. For your application, you need the older style with a vacuum advance unit hanging off the side.
Mar 20, 2018 at 6:18 AM
