Replacement alternator connector?
180,000 MILES
SHERMALE BARNETT
Replacing the alternator connector and need to know which wires go to what the new connector is a three wire. My car only has two, a black one with a white stripe and a white one with a red stripe which two wires from the new pigtail. Do I connect the gray, black and yellow?
Jan 28, 2023 at 12:33 AM
  • 110,248 POSTS
If you still have the old connector, you need to determine which wire goes to which pin in the connector and then attach the new connector wires accordingly.
I assume the new one didn't come with general wiring schematic, correct?
Also, if the new connector is a three-pin connector, are you sure it is the correct one?
Jan 28, 2023 at 2:28 PM
