Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Fuel System
Tank
Pressure Sensor
Fuel tank pressure sensor location and replacement instructions needed
2004 FORD EXPEDITION
230,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ANDRES210
MEMBER
1 POST
I cannot find a single diagram on the fuel tank pressure sensor location to replace it.
Jul 11, 2021 at 7:57 AM
Experienced Mechanic
Good afternoon,
The sensor is in the Evap line above the fuel tank. The tank must be dropped to gain access to the sensor.
I attached the procedure and the part from rock auto for you below.
I also attached the procedure for dropping the tank for you.
Images (Click to enlarge)
Jul 11, 2021 at 8:37 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
