Replacing radiator
2000 FORD COUGAR
120,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
GARY1984
I need to know how to replace the radiator. Mine is pushing water out of the top.
May 24, 2019 at 11:40 AM
  • 110,240 POSTS
Welcome to 2CarPros.
First, I am providing information for a Mercury Cougar (V6 2.5L) If that is incorrect, please let me know.
Here are the directions for replacing the radiator. The pictures attached correlate with the directions.
_____________________________________
PROCEDURES
Removal
All Vehicles
1. Disconnect the battery ground cable.
2. Drain the cooling system.
pic 1
3. Disconnect the radiator upper coolant hose.
Vehicles With Automatic Transaxle
pic 2
4. Disconnect the transaxle upper cooling line.
Vehicles With 2.5L Engine
pic 3
5. Disconnect the coolant expansion tank hose.
All Vehicles
pic 4
6. Remove the fan shroud nut.
pic 5
7. Detach the fan shroud and secure to one side.
8. Raise and support the vehicle.
Vehicles With Air Conditioning
pic 6
9. Secure the air conditioning condenser.
All Vehicles
pic 7
10. Disconnect the radiator lower coolant hose.
pic 8
11. Remove the radiator right hand bracket.
pic 9
12. Disconnect the transaxle lower cooling line.
pic 10
13. Detach the air conditioning condenser.
pic 11
14. Detach the transaxle cooling lines.
All Vehicles
pic 12
15. Remove the radiator left hand bracket and remove the radiator.
Installation
All Vehicles
pic 13
1. To Install, reverse the removal procedure.
pic 14
pic 15
All Vehicles
pic 16
2. Fill the transaxle.
All Vehicles
3. Fill the cooling system.
May 24, 2019 at 2:25 PM
