Replacing clutch and flywheel
155,555 MILES • 2.4L • 4 CYL • 4WD • MANUAL
SFCTRIPLETT57
  • 184 POSTS
When you replace the old clutch and flywheel, do you have to line the new flywheel with anything on the engine? I know you have to line the clutch up with the flywheel.
Thank you for your help, have an Army Day!
Larry Triplett
Army Vet
Iraq War Vet
Jul 29, 2021 at 10:17 PM
MASTER ASE TECH
  • 82 POSTS
Hi, I'm Dan.
The flywheel bolts directly to the crankshaft. On some Toyota engines the flywheel bolts are slightly offset so that the flywheel will only bolt on one way. But short answer is no, you don't have to line up the flywheel to the crank like you do with the clutch and pressure plate. The torque specs for the flywheel bolts is 80 Ft pounds.
Hoo-Ahh Sergeant.
Jul 30, 2021 at 6:50 AM
STEVE W.
  • 15,423 POSTS
Unless it has some odd type of bolt pattern or an alignment dowel as some externally balanced engines have, it should simply bolt on. Be sure to add some loctite to the bolts if they don't have thread locker on them already. I would check the pilot bushing or bearing though while you have it apart, if it's the original I would change it out. Easier to do it now than have it act up after it's all together. Be sure to put the clutch disc in the correct direction, have seen them put in the wrong way a few times, that can cause problems.
Jul 30, 2021 at 6:51 AM
SFCTRIPLETT57
  • 184 POSTS
Thank you so much Sir.
Jul 30, 2021 at 7:36 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just to add here this is a tutorial showing how to remove and replace a clutch assembly:
https://www.2carpros.com/articles/how-to-replace-a-clutch
I've attached picture steps below on how to replace the clutch on your Toyota truck. Hope this helps and thanks for using 2CarPros.
Jul 31, 2021 at 3:27 PM
SFCTRIPLETT57
  • 184 POSTS
Thank you very much Sir for your help.
Larry Triplett
U.S.Army 78-14
Iraq War Veteran
Jul 31, 2021 at 10:10 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Thank you for your service sir. Thanks again for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
Aug 1, 2021 at 9:27 AM
SFCTRIPLETT57
  • 184 POSTS
Sir, do I need a special tool to remove the flywheel!
Aug 2, 2021 at 6:44 AM
MASTER ASE TECH
  • 82 POSTS
No special tool needed, although a helper is advisable. The flywheel is heavy, once the bolts are removed the flywheel should stay in place, but once it wiggles loose, it can drop fast. Having someone hold the wheel while you remove the last bolt is advisable.
Aug 3, 2021 at 12:36 AM
SFCTRIPLETT57
  • 184 POSTS
Not many around here that will help, I’ve had to do it all alone but I do have a plan. Been in the Army long enough to have a plan to get the flywheel down with out help, I may pay someone to help me. It’s all jacked up off the ground working on my back.
Just like in the Army working on the old Willys Jeep, 2 1/2 ton Duce and half, 5 ton truck, M60 Tank and I could name more. Working in mud, rain, deep snow with a flashlight in my mouth, and working in 15 below weather and heat up to 125 plus. All I can say it was so much fun I want to do it all over again and again and again I think that’s enough for now.
Larry Triplett
U.S. Army 78-14
Iraq War Vet
Aug 3, 2021 at 9:42 AM
STEVE W.
  • 15,423 POSTS
Well, a trick that could help; take one of the flywheel bolts out, take it to a good hardware store and get a bolt with the same threads but longer. Cut the head off of the longer bolt and round the end over. Screw it into the top most bolt hole in the crankshaft. Now remove the other bolts and the flywheel will hang on that stud while you get positioned to pull it off.
Aug 3, 2021 at 10:30 AM
DANNY L
  • 5,648 POSTS
Hello again.
Just keep us updated and let us know if you have any further questions on this issue. Thanks again for using 2CarPros.
Danny-
Aug 3, 2021 at 12:02 PM
SFCTRIPLETT57
  • 184 POSTS
Thanks that's a great idea with the bolt, I didn't think about that.
Aug 3, 2021 at 10:11 PM
STEVE W.
  • 15,423 POSTS
Used it a few times for different things. Also works for things like lining up the transmission or other unwieldy objects.
Aug 4, 2021 at 1:16 AM
SFCTRIPLETT57
  • 184 POSTS
Thanks for the help.
Aug 4, 2021 at 3:46 AM
Good afternoon,
The flywheel is not that heavy at all. You can set it up on the crankshaft and start one bolt to keep it from falling off.
Start them all and tighten them to 40 lbs. Then retorque to the 80-pound spec that was delivered to you.
If you are happy with our site, feel free to write us a review.
https://www.sitejabber.com/reviews/2carpros.com
We are always glad to help.
Aug 6, 2021 at 6:20 AM
