Engine will not start
190,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ADAMNFLORES72
  • 5 POSTS
I replaced the water pump in the timing belt it started for maybe thirty seconds then the battery went dead. I charged the battery and I'm betting the 30 amp fuse blown under the dash and wont start.
Dec 19, 2018 at 7:51 AM
  • 55,802 POSTS
So does the engine crank over or it cranks over but wont start? Please let me know.
Dec 20, 2018 at 10:56 AM
ADAMNFLORES72
  • 5 POSTS
It cranks but i noticed wires to cam sensor was cut i spliced it it acts like it was to start but no luck.
Dec 20, 2018 at 11:23 AM
  • 55,802 POSTS
Can you turn the key to the on position without cranking the engine to see if your hear the fuel pump run for five seconds?
Here is a guide to help us see what's going on:
Dec 22, 2018 at 3:59 AM
