Replaced throttle body part,still bucking and no power
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KIRK / JEAN
Bought part online, throttle body, replaced it, car still bucking and little power. Am told the throttle position sensor is inside the throttle body part now, not sold separately for this car. Please advise.
Aug 28, 2019 at 5:33 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, what was done to diagnose the throttle body? As far as the throttle position sensor is concerned, you were given good information. It is internal in the throttle body, so if it is doing the same thing with the new part, chances are that isn't the cause.
Have you pulled any diagnostic trouble codes? Have you checked things like a plugged catalytic converter, fuel pressure, engine vacuum leaks and so on? If not, based on your description, the first thing I would check is for a plugged catalytic converter. Take a look through these links.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/catalytic-converter-replacement
Here is a link that explains how to find an engine vacuum leak:
Here is a link that explains how to check fuel pump pressure:
If the engine is running as you described, chances are the check engine light is on. If it is, you should scan it to identify the diagnostic trouble codes stored. That will help.
Let me know. By the way, I added the links not knowing what has already be done. Those are things that could possibly be associated with a power loss issue.
Let me know if that helps or if you have other questions.
Aug 28, 2019 at 11:15 AM
