Replaced starter with re-manufactured starters that does not sound right
1999 NISSAN ALTIMA
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
CCHIP55
  • 7 POSTS
Car listed above only has 60,000 miles as I travel a lot and telecommute for work.
However, I have been on a 2 month road trip so the car has been getting driven much more than it has for years. Two weeks ago the car wouldn't start and after getting the battery jumped and still car not starting it was determined that I needed a new starter. I had the car towed to a Firestone and the starter was replaced (with a re-manufactured part as they didn't tell me that's what they were going to put in). The very first time I started the car up after that it makes a rather loud screeching sound, but since I don't know cars and the technician let me drive it away from the shop, I hoped it wasn't a problem.
Someone then commented on the noise when I started it up another day, so took it to another Firestone and spent all day getting another starter put in (also re-manufactured - do they no longer make new starters or something?) and after spending all day in shop the new starter also makes the screeching sound.
I was told the car won't blow up and can drive it by Firestone, but that it could affect the fly wheel/wear the teeth down, but was told that typically only happens if car is old and has high mileage. My car is 20 years old, but as I mentioned it has extremely low mileage for its age.
I don't know what to do. I wasted 2 days of my trip sitting at Firestone all day and getting the starter replaced twice and my car doesn't like these crap re-manufactured parts. I also am still on this road trip doing a lot of driving for another couple of months and don't want to break down in cities I am not familiar with and where I know no one.
Is the car okay to keep driving with this re-manufactured starter? Can it do damage to other parts of my car if I keep driving it as is?
Help!
Jan 8, 2020 at 1:01 AM
CARADIODOC
  • 34,367 POSTS
There's two things that can cause the noise you described. The first is when the replacement starter isn't spaced correctly. That used to be a common problem on larger GM cars and trucks, and was always corrected right away, in the shop, by adding one or two shims that were included with the starter. The starter design used on your car doesn't need that type of adjustment and in fact, there is no adjustment built in.
The more common problem has to do with the splash shield typically used in the front of automatic transmissions. Corners on it often get bent, then the starter's drive gear scrapes on it when it pops out to engage the engine. That noise is indeed quite irritating and noticeable, but it doesn't cause other damage. That should have been noticed when the first starter was installed, and that is the mechanic who should have corrected it. The advantage to having this done at a franchise shop is usually their counterparts in other cities will take care of warranty work. You have to go back right away, otherwise they could legitimately assume the noise started weeks or months later and is not related to their work.
As for the rebuilt starter, this is what we refer to as "unreasonable expectations", but it has more to do with poor communication, something we are guilty of in this profession. You will never get a brand new starter except on rare occasions when the car is still under warranty. That means the manufacturer is supplying it and paying for it. As with generators, rack and pinion steering gears, and some other parts, a new starter would typically cost around $800.00 to over $1000.00.
When the starter is replaced, your old one was sent back through the parts store where the replacement came from, then back to the rebuilding company, as a "core". What you got was someone else's core that was rebuilt, then sold as such, for a fraction of the cost of a new starter.
Cores are tested first to determine what failed, then they're disassembled and all the parts that will be reused are cleaned up to look like new. That always includes the housing, the magnets or stationary coils of wire, and the rotating armature. Those parts also get replaced if they are damaged in any way, but 99 percent of the time they are reused. All the common wear parts are replaced, along with any other parts that prior testing showed to be defective. They also replace any parts that have a well-known history of failure, with improved parts, so in a lot of ways, a rebuilt starter will be more reliable than the original one was. That means the rebuilt starter is likely to be the highest-quality starter you can get. A brand new original equipment starter from the dealer will have all the same design shortcomings as the one that was removed from your car, so you're not gaining anything. The lowest quality product would be a used starter from a salvage yard, but even those can perform perfectly fine. After all, it was working okay when the car showed up at the yard.
The communication problem is part of what led up to your dissatisfaction. To anyone in the automotive field, the use of rebuilt parts is common knowledge and an industry-accepted practice, but that isn't always obvious to the car owners. The repair shop installed the standard part as expected, but no one bothered to make sure you were aware of that.
As a point of interest, we used to run into that with tvs too. A new picture tube would cost way more than the tv did when it was new, and the only way we got them was if the original one failed under warranty. Standard practice was to install a rebuilt picture tube, then send the old one back to be rebuilt for someone else. In over 35 years as a tv repairman, I only ran into two picture tubes being replaced with new ones, and both of those old ones were broken in shipping. To be considered "new", the tv could not be legally sold with a rebuilt part; it had to be a new part.
To revisit the design issue, GM had a 100 percent failure rate of their rack and pinion steering gear assemblies in the late '80s to early '90s. It was caused by wear taking place to the soft aluminum housing that allowed power steering fluid to bypass some internal seals. That resulted in loss of power steering assist when the engine was still cold. Their repair was designed to get the cars past the 50,000-mile warranty, then, when the problem occurred again, it was up to the owner to pay for the proper repair. That was to install a steering gear that had a stainless steel liner pressed in by the aftermarket rebuilding company. With those aftermarket parts, failures were just about unheard of. That is the perfect example of why a quality rebuilt part is far superior to a new one. The new one from the dealer would have been built with the same design flaw as your original one was.
The bottom line is I'm satisfied with the replacement starter they installed, but not with the noise. If it is going to be a long time before you return home, or before you can leave the car for a day, have someone at another Firestone shop document on the repair order the noise that resulted from their work. That is proof they are responsible for correcting the problem, even when it is at a later time. Be aware though, the original shop should be willing to get the car back in right away, but you can't expect that of some other shop that didn't cause the problem. They will already be booked up with appointments, and they may not have anyone free to get to your car right away. I would be quite pleased if they just agreed to get it in as soon as possible.
Jan 8, 2020 at 4:38 AM
CCHIP55
  • 7 POSTS
Thank you for the thorough and detailed reply. Plus the education on re-manufactured parts, which I now actually understand.
As I am on this long road trip, I wasn't able to travel back to the first Firestone shop that put in the starter and let me drive away with the terrible sound, but since the work came with a guarantee I went to a Firestone in the next city I traveled to. They took out the screeching starter and put another re-manufactured starter in and the result was the same, a screeching sound when they started it. The second Firestone shop didn't say anything about the starter not being spaced correctly or issues with the splash shield by the first Firestone (even though at the 2nd Firestone the Master Technician is the one who worked on my car). What they said when the 2nd starter had the same result/noise is that the re-manufactured parts weren't working and I needed an actual Nissan starter, not whatever brand the 2 re-manufactured starters were - the store clerk even wrote it down for me.
After things being so messed up and wasting 2 days off work trying to deal with Firestone I made them give me a full refund for the part and labor. I was going to try to get to a Nissan dealership to get a 'Nissan starter' as advised by Firestone, but it's harder to get an appointment than at a Firestone type place, plus they were going to charge me double what Firestone did for the part and labor.
So as long as you are basically saying the annoying noise won't do damage to my car or cause the starter to fail to start the car, I guess I will just live with it, or at least put off doing anything while I continue this road trip for another couple of months... I just didn't want to put myself or the car in danger.
I cannot express how much I truly appreciate your knowledge and the time you took to write out such a detailed answer for me. I am a woman on this long road trip alone and having to worry about being stranded in towns I am not familiar with and don't know anyone in has been a big worry and was impacting my trip. Thank you, thank you!
Jan 8, 2020 at 7:30 AM
CARADIODOC
  • 34,367 POSTS
I'm pretty confident the starter is not the issue. When one is rebuilt, it gets a series of tests, and no rebuilder would let one go making an abnormal noise. And your chance of getting two like that from two different cities is even more unlikely.
These rebuilt starters you're getting are Nissan starters that failed on someone else's car, got returned to a rebuilder, then sent out to the auto parts stores. Most new-car dealers buy their starters from the same rebuilder companies; you're just paying more for the same thing. You can request a brand new Nissan starter, but as i mentioned, it will cost a lot more. Depending on how long ago that starter was manufactured, it could have the same design shortcomings, or the same lowest-cost parts they could find that would do the job, as your original starter had.
Your car is 20 years old, and parts like starters are often the same for many years, so it is likely your starter part number was used for another ten or 15 years. In that time, when a manufacturer learns of a high-failure part, or some common repair history, in the name of quality, they will redesign some aspect of the part, or use a stronger part or one less prone to wear. That is a potential reason a new starter from the dealer could be better than your original one. On the flip side, when a manufacturer identifies a troublesome part and develops an improvement, that improvement will find its way to the rebuilder companies too, then that improved part will become part of their standard rebuilding process..
To say that a different way, a rebuilt starter or a new one from the dealer could both be better than what came off your car. My concern now is what is the dealer going to blame if the noise is still there?
To add another dimension to this sad story, back in the '70s, my friends and I loved the old Chrysler products. Chrysler was the world's leader in developing innovations that benefited car owners like us. One of them was their starter design that for many years could be modified for use on GM race engines because Chrysler's were the only ones strong enough to start those engines. Their popular design first showed up in 1960, then, by around 1968, they looked the same and interchanged the same through all the years, but the internal parts were completely different. Then they were resigned again a few times through the late '80s. Any starter from any year could be used on any year car, but if you wanted to repair one yourself, as we always did, you had to buy the correct set of parts for the individual starter. Each design change resulted in improved reliability, improved ease of service, more resistance to the effects of engine heat, or reduced weight. If you were to buy a brand new starter from the dealer's parts department, you could get one that was manufactured in 1989 to the latest and most-improved design, or you might get one that was built in 1972 and has been sitting on the shelf for many years, with an inch of dust on the box.
In the case of Chrysler, and most other manufacturers, when a part gets a major redesign, it gets a new part number. This is why when looking up parts on an auto parts store"s web site, or even in their parts books on the counter, they will list multiple part numbers this new one will replace and work in place of. When only a small change is made, such as switching to a stronger bolt, or adding some metal to a weak spot in the housing, they will only change the suffix of the part number. For example, radios I work on might have a part number of 5265418AA, and the next one will be 5265418AB. Those are the same radio and they fit the same applications, but by the time the one ending with "AB" came down the assembly line, a minor, but significant change was made to the design. In one example I'm aware of, one small component was changed to replace one that was susceptible to changes in temperature, and it resulted in the stations drifting a little over time. That one part was responsible for improved customer satisfaction, but it didn't warrant a whole new part number for that radio. Every letter higher in the suffix denotes a change was made compared to the ones with the previous letters.
Getting back to the reason I brought up the Chrysler starter story, those were real easy to replace when the car was up on a hoist, but it could be a miserable job when laying on the ground. There was a sheet metal plate on the front of the transmission with a hole in it for the starter to sit in. When struggling on the ground and removing the starter, it was real easy to let it hang by its own weight, and bend a small area around that hole. You couldn't see that damage by eye, but once reinstalled, the starter made that same screeching noise you're experiencing. Most of the time we were putting the original starter back in that we had just taken out, so you know the starter wasn't the cause of that noise. At times this became frustrating because we had to take the starter back out, try to find the bent spot in the sheet metal plate, bend it back straight, then stuff the starter back in. Once we went through all that work, about half of the time the noise was still there, and we had to start all over.
Today I'd like to think I'm smarter, but I still like to repair an old starter instead of buying a rebuilt one. Instead of crawling around on the ground, I pedal to my friend's shop and use his hoist.
Since I am rather confident the starter is not causing the noise, and since it is starting your engine just fine, I would request the next mechanic to repair, straighten, or replace the splash shield. On most cars, that shield is fairly easy to remove as a temporary test to prove that is what's causing the noise. Most of the time, with it on the workbench, you can see the shiny or ground-down area where the rubbing was occurring. If bending it back to proper shape is too difficult, the offending area can be ground or cut away without causing any other problems. The shield is there to keep fingers and rocks out. They shouldn't have to replace the starter again unless that would make you feel better.
Regardless of how this is handled, please keep us updated on your progress and on what the final solution involves.
Jan 9, 2020 at 3:28 AM
CCHIP55
  • 7 POSTS
Again, thanks for the education. I think I will keep going with my trip and once I am in a place long enough (and can get a recommendation for a good local mechanic) I will have them test the splash shield in the way that you said and if the noise disappears, I will have the mechanic grind or cut away any part that is rubbing.
Again, I am very grateful for your expertise and hope that if it takes me a couple more months before I can do the above, that it won't be a problem other than the annoying noise. :)
As a former educator I appreciate the 'teaching moment' you gave me by sharing your knowledge.
Jan 9, 2020 at 8:45 AM
CARADIODOC
  • 34,367 POSTS
I'll be waiting to hear back.
Jan 9, 2020 at 9:25 AM
CCHIP55
  • 7 POSTS
Hello CardioDoc,
I bet you didn't think you would ever hear back from me. I am sorry, as I didn't mean to leave you hanging after all your helpfulness. a little thing called a pandemic happened during my road trip which changed everything. I have been forced to shelter in place for months and the only time I drive the car is to the grocery store once every 2 weeks, so there wasn't much of a reason to be thinking about the flywheel.
That said, I was able to get a recommendation from someone for a car place and took my car there last week. Just to remove the starter to confirm what I told them you told me, they wanted $100.00! Then the guy said (he had a strong accent which was hard to follow) something along the lines of worse case scenario of the problem is x, he was going to charge $800.00. Wow, considering my car is a 1999 and unfortunately the Blue Book value is about $250.00 despite the still low mileage of 63,000 even despite my road trip, I just said never mind and left.
Maybe if I am ever able to continue on with my trip, I will worry about it then and try to take it somewhere, but for now that seems like it may be a long time off if ever. Also, it's possible that maybe I have gotten so used to the sound upon starting the car up, that it doesn't seem so bad. But I really think the sound has gotten less screechy! Is it possible that during the months I was driving all over after the starter was put in that it rubbed on the part of the flywheel that was the problem and has kind of solved itself?
I hope this message finds you safe and healthy.
May 11, 2020 at 3:54 AM
CARADIODOC
  • 34,367 POSTS
Yup. If the drive gear is rubbing on the splash shield when it pops out to engage, that sheet metal shield is going to wear away, then the noise will be reduced or go away. We could be talking about eighths of an inch or even less, which is quite insignificant.
May 11, 2020 at 4:37 AM
CCHIP55
  • 7 POSTS
Good to know, I don't think it is my imagination that it doesn't sound as bad as it did when both starters were put in. I mean it doesn't sound as good as it did before I had the starter replaced, but it doesn't make me cringe or people nearby jump in the air. Therefore, do you suggest I still try to take it to another shop?
For me, as long as it doesn't cause any problems to the car, and driving it more regularly would be fine when we can resume as semi-normal existence, I would be good with that. If the rubbing on the flywheel will cause any future issues, then I will try again. Please let me know!
Thank you again for sharing your knowledge with me.
May 11, 2020 at 5:02 AM
CARADIODOC
  • 34,367 POSTS
The flywheel isn't the issue. That is spinning any time the engine is running, so you'd hear the noise all the time. Since the noise is only there during cranking, it has to be the starter's drive gear that is involved, and that only extends out to the teeth on the outer edge of the flywheel when you're starting the engine. Once the engine has started running, that drive gear retracts, and presumably retracts away from what it is rubbing on.
May 11, 2020 at 5:34 AM
CCHIP55
  • 7 POSTS
So bottom line, is that causing damage to the drive wheel? Is the car not okay to drive?
I need to know if I should be doing something more about this or not.
Thanks
May 11, 2020 at 5:55 AM
CARADIODOC
  • 34,367 POSTS
Drive it. Many years ago this was more common, and we just kept on driving, especially if remedial repairs involved crawling around on the ground under the car.
May 11, 2020 at 6:25 AM
  • 110,240 POSTS
Thanks for letting us know. Please feel free to come back anytime in the future if you have questions.
Jun 21, 2022 at 8:43 AM
