After replacing the power steering pump and pully, there is clunking sound and burning rubber smell?
130,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WILL HUNTER
  • 13 POSTS
So, I just replaced the power steering pump and the pulley on my 1995' G30. After replacing the belt also, there is a clunking noise from the belt tensioner and a smell of burning rubber. I've heard you have to brake in new belts, but I wanted to be sure before I let it run and potentially damage anything. Thanks for the help!
-Will
Feb 20, 2023 at 1:55 AM
  • 110,248 POSTS
No, that isn't normal. It appears as if the belt tensioner pulley isn't turning. Can you check that for me? And no, you shouldn't smell rubber burning. I have a feeling the pulley is stuck on the tensioner and burning the belt.
Check that and let me know what you find.
Feb 20, 2023 at 9:40 AM
  • 55,677 POSTS
Thanks for the video, it helps. I would remove the serpentine belt and spin each accessory such as the alternator and power steering pump. Also, it like looks like the engine may have a running issue so please start the engine once the belt is off for about 5 seconds to see if the engine is okay or not. Please let me know what you find.
WILL HUNTER
  • 13 POSTS
Hey Ken, turns out I just needed to replace the belt tensioner pulley as it had seized up. Also the belt might have been on wrong. Now she runs great. Hope this can help someone! and thank you for the response!
Feb 21, 2023 at 12:02 AM
WILL HUNTER
  • 13 POSTS
I reread Joe's response and he was spot on!
Feb 21, 2023 at 12:03 AM
  • 55,677 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Feb 21, 2023 at 12:43 AM
