Replaced rotors and pads per your video
2001 CHRYSLER PT CRUISER
106,000 MILES • 2.4L • 4 CYL • FWD • MANUAL
RUBENGUAJARDO
  • 6 POSTS
The calipers rub against inside of rim. I checked and reassembled 3 times still can't solve issue. I've checked with dealership and 2 aoto parts stored. They list 1 one rotor for this. Any ideas what I'm doing wrong?
Sep 28, 2015 at 12:26 AM
HMAC300
  • 48,601 POSTS
you probably have the mounting bolts for caliper mounted in wrong place we dont' have any pics to show on this. I checked on rock auto and some rotors are 11-11.25" in diameter an dothers are 10.63" see which you have
Sep 28, 2015 at 12:34 AM
RUBENGUAJARDO
  • 6 POSTS
Rotors are good. There only one way to bolt calipers on. How can you do this wrong? I agree with you. I just can't figure out what I did wrong.
Sep 28, 2015 at 12:42 AM
HMAC300
  • 48,601 POSTS
re read my first reply also are they different wheels ? that may be problem.
Sep 28, 2015 at 12:46 AM
RUBENGUAJARDO
  • 6 POSTS
I checked the mounting bolts for caliper, those are installed right. I put the old pads on and I have about a sixteenth clearance now. Parts store said I have the right pads.
Sep 28, 2015 at 2:30 AM
HMAC300
  • 48,601 POSTS
do the old pads match with the new ones if they do then it's something else. did you push the caliper piston back into the caliper all the way? that may be the problem. are they rear disc brakes and parking brake has ben bottomed out ? you didn't say front or back finally are the rotors seated correctly on the hub? may not be.
Sep 28, 2015 at 3:05 AM
RUBENGUAJARDO
  • 6 POSTS
Sorry, front brakes. Pads match up to old ones. Could the pads be too thick?
Sep 28, 2015 at 3:30 AM
RUBENGUAJARDO
  • 6 POSTS
I'm truly stumped.
Sep 28, 2015 at 3:31 AM
RUBENGUAJARDO
  • 6 POSTS
I did check hub fit and the other items as well.
Sep 28, 2015 at 3:37 AM
HMAC300
  • 48,601 POSTS
if pads are to thick then it's because you didn't back the caliper piston back into the caliper. the piston should be flat against edge of caliper . I have no further comments because I can't see it nor know what you did
Sep 28, 2015 at 5:02 AM
RUBENGUAJARDO
  • 6 POSTS
Thanks anyway...
Sep 28, 2015 at 5:07 AM
