"Stupid is supposed to hurt."
My stupid today: I completely forgot how to bleed brakes properly, but I didn't realize it. ouch.
I had my brake warning light coming on periodically for the last week or so. I inspected the brakes at each wheel. I found the rear driver side caliper with a small leak around the piston. I replaced that piston. Once installed I began to bleed the caliper. I did this by having my wife pump the brake peddle repeatedly while the engine was on and the valve on the caliper was open. (yea, I know) The result was that I watched the brake pressure steadily decrease with each stroke of the peddle until there was just a trickle of brake fluid coming out of the valve. After cussing and scratching my head I realized the error of my ways and cussed some more. Then with the help of a much more experienced friend, began to recover.
Right now we are stuck. There is still pressure forming when bleeding the rear driver side. There is pressure when bleeding all three other wheels. When braking during a test drive the peddle goes to the floor.
What are we missing?
Why is the overall stopping affected so much? Shouldn't the front brakes be unaffected?
What question should I be asking?
Apr 4, 2019 at 8:37 PM
