Replaced old starter in 1978 Ford E350 Van, Now it won't turn over.
JELLYFYST
My old starter stopped turning the engine. Recently replaced the battery and the starter solenoid. Now the van won't turn over. The Lights in the cab still work. I get one Click response when I turn the key over. any Ideas? Maybe not grounded, but how do I double check that?
Sep 26, 2013 at 7:17 AM
  • 31,937 POSTS
Check all electrical connections, if they are ok, probably a failed starter motor.
Sep 26, 2013 at 7:24 AM
  • 75,988 POSTS
I agree, sound more like the starter motor has failed-
Sep 26, 2013 at 7:45 AM
JELLYFYST
I Put in a New Starter Motor. The old Starter responded with Multiple Clicks when I turned the key. The new Starter only responds with one click when I turn the key.
Sep 26, 2013 at 7:47 AM
  • 75,988 POSTS
Check the starter relay that's if it has one and double check all connections involving the starter motor-
Sep 26, 2013 at 7:58 AM
  • 31,937 POSTS
I presume that you can turn the engine by hand and that it is not starting to lock up?
Sep 27, 2013 at 9:31 AM
