Replaced O2 sensors cannot clear codes
189,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
BARENNA12
I replaced the O2 sensors, but cannot clear the error codes in the ECU. I tried 'clear codes' using a diagnostic tool and I tried disconnecting the battery and draining it. The codes remain in the ECU without starting the car up.
Nov 16, 2017 at 12:22 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you cannot clear the codes, then most likely that means that replacing the O2 sensors did not fix the problem. Error codes do not always mean a sensor is bad, it just refers to the circuit, so it could be a problem with the circuit wiring.
Nov 16, 2017 at 6:06 AM
STEVE W.
  • 15,423 POSTS
What are the actual codes you have? What tool are you using to clear them?
Nov 16, 2017 at 6:18 AM
