The timing went so I had the motor replaced. After that it ran fine the first start up then it started doing weird things like; check engine light staying on when car was off and key was put, continues running after key is turned off and removed, and starting by itself once battery is connected. Can this be due to bad ground, alternator feedback, or ECU problem? Please I really need help!
Nov 3, 2019 at 10:51 PM
