Replaced fuel pump still not starting
2005 DODGE MAGNUM
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BANTS
Replaced fuel pump still will not start. i am getting fuel and the pump is operating fine, but my car still will not start. It has power to everything, fluids are good, just cranks and cranks no start.
Jan 17, 2019 at 11:40 AM
SCGRANTURISMO
  • 4,897 POSTS
Hi Bants, my name is Alex and I will be helping you today. You may have a problem with your Crankshaft Position Sensor. Here are couple of helpful links that I think will help:
https://www.2carpros.com/articles/symptoms-of-a-bad-crankshaft-sensor https://www.2carpros.com/articles/crankshaft-angle-sensor-replacement
Jan 17, 2019 at 4:07 PM
