Replaced crank sensor and fuel pump
215,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
KUNTRYBOY SHINAGROVE
Sometimes no start, sometimes cuts off while driving. when I hit the computer it may crank. How much is a computer?
Jan 26, 2018 at 8:45 AM
  • 31,937 POSTS
you need to check a spare parts outlet or a dealer for that price. hitting electrical components is not advised. check that the main electrical plug into the PCM is clean and tight first. clean contacts with electrical contact cleaner as this will help if there is any fretting with the terminals.
Jan 26, 2018 at 1:04 PM
