Replaced coolant sensor engine light on now
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DJGAZELL
  • 7 POSTS
Also gear shifter is making noise when slowing down.
Dec 28, 2019 at 7:28 AM
Good evening,
Why did you replace the sensor?
What is the code that is set?
What kind of noise is the shifter making? Can you upload a video of the noise for me?
Dec 28, 2019 at 8:36 AM
DJGAZELL
  • 7 POSTS
Replaced the coolant sensor because i was having cold start problem..but here is a video of the noise:
Dec 28, 2019 at 2:21 PM
DJGAZELL
  • 7 POSTS
Don't know code yet.. doing that in the morning.
Dec 28, 2019 at 2:52 PM
Okay, thanks.
Let me know the code.
Dec 28, 2019 at 9:57 PM
DJGAZELL
  • 7 POSTS
No codes now. No light. Had a vacuum hose unplugged, but i'm have cold start problem again and the idle rpm's are really low; 500 barely running.
Dec 30, 2019 at 12:24 AM
Okay, the first thing I would do is check the fuel pressure to be sure the pump is supplying enough fuel when cold.
Dec 30, 2019 at 12:39 AM
DJGAZELL
  • 7 POSTS
Replaced MAP sensor and TPS.. now wont even stay idling weather hot or cold. new code for IAC malfunction, but i replaced that 3 weeks ago and fixed itself for a bit.
Dec 30, 2019 at 12:37 PM
Need the code number.
Did you check the fuel pressure.
Dec 30, 2019 at 4:26 PM
DJGAZELL
  • 7 POSTS
Everything working now. clogged air valve.. but now when i start it it idles fine for 3 seconds then raises to 1,500/2,000 rpm's. i replaced IAC 3 weeks ago so it shouldn't be that. no engine light.
Jan 1, 2020 at 6:39 AM
Pull off the wires to the IAC and see if the idle is normal. What valve was clogged?
Jan 1, 2020 at 7:14 AM
