After replacing brake light sensor car will not start
65,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
SHERYLR
  • 8 POSTS
I started my car and couldn’t get it out of park. Found out the brake lights didn’t work either, fuses were fine so we replaced the brake light sensor. Now my car won’t start. No clicking, nothing. All the lights go on but it won’t start. Tried resetting the theft mode, didn’t work.
Apr 29, 2019 at 1:44 AM
Good afternoon,
Did you verify the battery is not dead?
Test it with a volt meter and be sure it is 12.6 volts.
Does the car come out of gear now?
Apr 29, 2019 at 2:28 AM
SHERYLR
  • 8 POSTS
We checked the battery, it’s fine.
Apr 29, 2019 at 3:34 AM
SHERYLR
  • 8 POSTS
Sorry, i can also move the shifter out of park.
Apr 29, 2019 at 3:45 AM
What is the battery voltage? I need numbers, please.
Apr 29, 2019 at 5:01 AM
SHERYLR
  • 8 POSTS
As soon as my brother in law gets off work I’ll have him run the volt meter. Thanks Roy.
Sheryl
Apr 29, 2019 at 5:07 AM
You are welcome.
always glad to help.
Apr 29, 2019 at 5:13 AM
SHERYLR
  • 8 POSTS
Okay, so it’s 11.6 and while it’s in park it rolls. But now it starts while it’s in reverse! So reverse is reading neutral. It’s got no park or reverse.
Apr 29, 2019 at 7:18 AM
Okay, 11.6 is a dead battery. It needs to be charged to 12.6 and then see what happens.
Apr 29, 2019 at 7:59 AM
SHERYLR
  • 8 POSTS
We put the car in reverse and it started right up. We put the car in park and it goes in reverse but it goes forward in drive.
Apr 29, 2019 at 8:04 AM
Well, then your reading is wrong on the battery.
Below is the procedure for adjusting the transmission shift cable. You need to do this for it to start in park and neutral.
Cable Adjustment
1. NOTE: Make sure that the range selector lever is tight against the rearward overdrive stop.
Place the transmission range selector lever in the overdrive position.
2. Raise and support the vehicle.
3. Loosen the manual control lever nut.
4. Place the transmission manual control lever in the overdrive position.
5. Tighten the nut on the manual control lever.
Apr 29, 2019 at 9:06 AM
SHERYLR
  • 8 POSTS
All right, we’ll give that a try. Thank you for all your help Roy, I really do appreciate it!!
Sheryl
Apr 29, 2019 at 1:27 PM
Your welcome
Apr 29, 2019 at 7:19 PM
SHERYLR
  • 8 POSTS
Underneath the car. Anyway thanks again!
Sheryl
May 1, 2019 at 9:25 PM
Yes, under the car
May 1, 2019 at 9:43 PM
