replaced battery but car will still not crank
2001 JAGUAR S-TYPE
124,000 MILES • 6.0L • V12 • 2WD • AUTOMATIC
RATH7073
my son ran my car low on fluids so it quit running. Then it sat up for about a year and we did not crank it. so i put a new battery in it but it will not even turn over.
Mar 27, 2018 at 11:10 AM
  • 31,937 POSTS
Start with checking power to the main starter terminal that should be hot all the time, and check for twelve volts at the starter solenoid wire, the small wire on the starter. this should only have twelve volts with the key on crank. if this is the case the starter is faulty, if nothing at the solenoid, check range switch, relay and ignition switch start here.
Mar 27, 2018 at 8:43 PM
