Replaced Alternator, Unsure of how to fit belt back on?
2.0L • MANUAL
VTMENACE802
I took out my old alternator and just untightned the tensioner on that to pull the belt off, however once I put the new one back in I had to have the alternator unbolted then force it back into place to put the pivot bolt back on. Once on I could not even feed the tensioner bolt back into the top of the alternator due to the belt already being so tensioned, it moved the top of the alternator just above where it needed to sit on the side of the bracket the tensioner sits on.
Aug 16, 2026 at 6:57 AM
KRAKENAUTO
  • 107 POSTS
There's an adjustment bolt (A), you need to loosen them all (not remove completely) then you should be able to get it on and adjust from there. See image for reference.
Aug 16, 2026 at 11:03 AM
