replace starter mounting bolts
2001 DODGE CARAVAN
100,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
CHEFROB
what length and thread pattern do I need for the bolts that mount the starter to the engine block
Sep 7, 2021 at 3:14 PM
SQM
  • 6,383 POSTS
These vehicles uses M10 x 1.5 in 50 mm length. Depending on the replacement starter it may or may not need shims.
Typically you will be able to get the replacement bolts your local auto parts store. Most place will be able to look it up by the make and model.
Sep 7, 2021 at 4:24 PM
CHEFROB
Sep 8, 2021 at 8:06 PM
SQM
  • 6,383 POSTS
You're welcome.
Sep 9, 2021 at 12:02 AM
