replace rear wheel bearings
95,000 MILES • 4 CYL • AWD • AUTOMATIC
JOSEPH VINYARD
  • 8 POSTS
cannot get hub out of bearing and off cv axle
Dec 30, 2015 at 8:37 AM
CARADIODOC
  • 34,414 POSTS
Front or rear? What are you trying to do / how are you trying to get this apart?
Dec 30, 2015 at 8:54 AM
JOSEPH VINYARD
  • 8 POSTS
rear using slide hammer puller on hub
Dec 30, 2015 at 9:01 AM
JOSEPH VINYARD
  • 8 POSTS
trying get hub off cv axle and out of bearing so can replace bearing on rear 06 element awd
Dec 30, 2015 at 9:03 AM
CARADIODOC
  • 34,414 POSTS
The bearing is replaced as an assembly by removing five bolts. You can buy just the bearing but you still have to unbolt the entire hub assembly, then use special tools to pull the hub out of the bearing, then the bearing out of the housing. It's much faster and easier to just replace the assembly.
Dec 30, 2015 at 9:18 AM
JOSEPH VINYARD
  • 8 POSTS
cannot get cv axle shaft out of hub so i could do that. is there a clip on axle to keep it from pushing out of hub
Dec 30, 2015 at 9:22 AM
CARADIODOC
  • 34,414 POSTS
Nope. Just a splined shaft that might be rusted in. Obviously, be sure the nut has been removed from the cv joint. You can try pounding on the end of the joint with a hammer, but you run the risk of damaging the threads. If you have a new nut, as many of them are one-time-use-nuts, put the old one on backward a few threads, then pound on that.
You can also use a bearing puller that bolts to three of the wheel studs, and has a center bolt that is screwed in to push on the joint. It isn't common to have to resort to that.
Dec 30, 2015 at 9:47 AM
JOSEPH VINYARD
  • 8 POSTS
ok thanks for info
Dec 30, 2015 at 10:03 AM
