Replace rear wheel bearing 2003 ml350
2003 MERCEDES BENZ ML350
128,000 MILES • 3.7L • 6 CYL • FWD • AUTOMATIC
THESANDMAN
  • 38 POSTS
Right rear bearing is going bad. Do I remove the axle and pull the hub assembly this from the backside? Will a universal wheel puller work on this job?
Jan 4, 2016 at 5:46 AM
PACO8224
  • 117 POSTS
You do have to remove the axle out the way, and use the puller to remove your bearing from the backside of it pulling it outward. don't forget to remove the o ring clamp in front of bearing.
Jan 10, 2016 at 6:41 AM
