replace ignition now engine will not stay running
2007 PONTIAC G6
120,000 MILES • 3.5L • V6 • TURBO • 2WD • AUTOMATIC
JOSH HILL
car will start run just a minute then shuts off.
Jan 4, 2020 at 5:32 AM
  • 110,244 POSTS
When you say ignition, what was actually replaced? For example, was it the switch, the ignition coil, and so on.
If it was the switch, have you programmed the system to recognize the new key? It may be shutting down due to the anti theft. Try this. Turn the key to the run position (engine off) and see if the theft light turns off. If it does, see if it starts then.
Jan 4, 2020 at 11:38 AM
JOSH HILL
okay, I'll try it tomorrow. I put in a ignition the locking part at first it wouldn't do nothing. so I reprogram it now it starts runs a minute then shouts off.
Jan 5, 2020 at 4:39 AM
  • 110,244 POSTS
Sounds like a plan. Let me know what you find.
Jan 5, 2020 at 10:05 AM
