BCM replacement
101,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
CNLOOPER
  • 11 POSTS
What are the steps to replace a fuse panel box on the passenger compartment and will it have to be reprogrammed?
Mar 22, 2016 at 7:40 AM
You will require a scan tool capable of performing the needed functions of programming the PCM and BCM after the BCM replacement. I attached the info needed.
Also, you are going to have to program the keys to the new BCM as well.
Let us know if you require more information. Thanks
Dec 4, 2020 at 7:45 AM
