it's showing cam sensor codes and wont start
220,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DJGAZELL
  • 7 POSTS
Replaced fuel pump drove home about 15 miles put $20.00 of gas in now gauge wont work and it's showing cam sensor codes and wont start. when it does crank over it really rough.
Nov 2, 2020 at 1:47 PM
We need to start with a couple of things. First we need to check the fuel pressure just to make sure that is correct even though you have a new pump.
Then we need the actual codes that you have so we can try to determine what the possible issue is. Once we know what codes you have we can run through the testing.
Nov 3, 2020 at 2:35 AM
