Replace Fuel Lines
30,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
SLIMNOTSHADY
I am trying to run new fuel lines on a 1970 Chevelle. I have heard that I need to remove the body from the frame to do this, but I do not want to risk doing that because I can potentially damage my car.
1) I am wondering if it it possible to run new fuel lines on this car without removing the body?
2) Also I think that if i cut the fuel lines I can install them without removing the body but how dangerous is it to cut a fuel line a reattach it afterwards with a flaring tool? I have heard for safety reasons not to cut fuel lines.
Feb 11, 2016 at 1:37 PM
WRENCHTECH
  • 20,758 POSTS
As you were told at the other forum, it you plan to use pre-bent lines, you would have to remove the body to do it without bending them.
Feb 11, 2016 at 6:23 PM
SLIMNOTSHADY
Ok I really appreciate your timely response. Would you happen to know the diameter of the size line needed?
1970 Chevrolet Chevelle
350 Small Block V8(5.7 cubic liter) / TH400
Feb 12, 2016 at 10:24 AM
WRENCHTECH
  • 20,758 POSTS
It's probably 3/8 but you need to measure the old ones
Feb 12, 2016 at 10:26 AM
