ECM swap
2004 BUICK CENTURY
180,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
409SANTANA
  • 14 POSTS
Can i swap the ECM from one car to another without any complications?
Aug 13, 2019 at 7:28 AM
Good afternoon,
No, you cannot. You would need to find one with the exact same number for the PCM. Then you have to change the prom from yours to the donor.
Then it should be flashed or programmed to your exact car.
Aug 13, 2019 at 7:34 AM
409SANTANA
  • 14 POSTS
Thank you. how much and where can i have the ECM reprogrammed?
Aug 13, 2019 at 7:54 AM
Any shop that has the scan tool to perform this can do it for you.
In my area, it runs around $150.00.
You are welcome.
Aug 13, 2019 at 7:57 AM
