Replace drive side power window switch
173,000 MILES
JDREWF
What are the steps to replace/repair the drive side power window switch cluster. It appaears to me that the screw that secures the top of the cluster has fallen out. how do I remove the arm rest section to obtain access to the swith to replace the screw or replace the switch
May 5, 2013 at 1:27 AM
take a screw driver and pop up the master switch to access the acutal control.
do you have the new one????
May 5, 2013 at 2:20 AM
JDREWF
Ok, So I pry up the siler plastic insert in the arm rest holding the power window switch. No I do not have a new one at this point in time, I just want to inspect the one I have. The The Switch cluster still work it appears that the screw/clip that holds the cluster to the silver plastic insert in the door handle has dropped/out/come off so that when you try and drpress the switch the whole cluster is pushed back into the door. Only the top screw/clip has come off not the bottom screw/clip.
May 5, 2013 at 2:33 AM
