Crankshaft pulley harmonic balancer installation
44,500 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KARYSART
Need to know if the large bolt in the center of the pulley I need to remove is counterclockwise or regular clockwise. Thanks so much for your help!
May 29, 2020 at 7:28 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It is counterclockwise and should be either 19 or 22 millimeter socket for size. Let me know any other information you need for this question at all.Hope this helps and thanks for using 2CarPros.
May 29, 2020 at 9:30 PM
Good morning,
It is a standard bolt that release counter clockwise but is very tight. I suggest using an air gun or a strong electric gun.
https://www.2carpros.com/articles/front-main-seal-replacement
May 29, 2020 at 9:32 PM
KARYSART
Thanks so much for the information, very helpful!! Will tell my buddies about your site!!!
May 30, 2020 at 12:08 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Let us know how things turn out and if you have any further questions on this issue.Thanks again for using 2CarPros.
Danny-
May 30, 2020 at 5:34 PM
