Engine stalls random, then restarts after a few minutes. replace crank position sensor.
Jun 17, 2019 at 11:23 PM
✓Experienced Mechanic
Welcome to 2CarPros.
The first thing I need you to do is check for diagnostic trouble codes. This has an OBD1 system and you can check it at home. All that is needed is a short jumper wire or even a paper clip.
Follow the directions in this link and let me know the results.
