Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Marquis
Exterior Light
Brake Light
REPLACE/REMOVE
Replace break light bulb.
2007 MERCURY MARQUIS
63,000 MILES • 4.1L • V8 • 2WD • AUTOMATIC
HARRY DAY
MEMBER
1 POST
Driver side break light is out.
Feb 10, 2016 at 10:49 AM
HMAC300
Experienced Mechanic
assuming you have checked the bulb check to see if you are getting power at the lt. grn /org wire if you are then it may be a bad socket or ground if no power see if it is coming from multi function switch on steering wheel.
Feb 10, 2016 at 10:28 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
