Speedometer swap
1989 FORD PROBE
200,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
JLGLOBAL
My speedometer is toast. I would like to replace it cheap with one from a later model non turbo. The only difference I see is the gauge goes to 120 mph on the 1989 GT and 100 on everything else. Will it still read the correct mph? What happens when I do 135 mph in it?
Dec 5, 2018 at 10:01 PM
  • 110,244 POSTS
For the speedometer to work properly, you have to replace it with the original type. The system is pre-calibrated specifically to your speedometer.
Dec 6, 2018 at 10:52 AM
