Need repair quote before purchasing this car
99,000 MILES • 1.6L • 2WD • MANUAL
CIRCUSLION101
Hi, i wanted to get a quote for a repair before I buy a car.
Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c).
Offside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c).
Nearside Front Tyre worn close to legal limit/worn on edge (5.2.3 (e).
I'm aware tire prices may vary I'm more concerned about the other bits.
Thanks,
George
Mar 18, 2020 at 4:46 AM
  • 110,251 POSTS
Hi George.
Normally, we don't quote prices but rather help people determine problems and how to repair. If you provide tire size and exactly what needs replaced, I can help with labor time and approximate price.
Mar 18, 2020 at 4:58 AM
Unfortunately it is near impossible to give you an accurate estimate on something like this because we are not looking at the vehicle.
The fact that you have what sounds like an oil leak there is no way we could give a complete estimate plus we typically stick to helping diagnose vehicles. There are times when we will evaluate an estimate that was provided but even then we are limited to what others have found.
Sorry we can't directly help with getting prices like this. If you get the specific part that they are reporting needs replaced, we can get you a labor time and then we can get close to what it will need.
Mar 18, 2020 at 5:36 AM
