Changed oil now white/gray smoke coming out of exhaust
165,000 MILES
MAJRAM
White/gray smoke coming out of exhaust after oil change, air filters replaced. What is the diagnosis? Change in the way the car is running, noticed a shaking.
Aug 17, 2018 at 10:19 AM
  • 55,746 POSTS
I would check the oil level first also did you add the oil in the correct place? Also, if the air filter is not on right it can cause the crankcase ventilation system to suck raw oil into the intake. Here are videos on both job can you go over them to see if you did something wrong?
https://youtu.be/aNvfRHuZTFY
and
https://youtu.be/DyzHYXhrU5o
Cheers, Ken
Aug 18, 2018 at 11:43 AM
  • 110,248 POSTS
Honestly, it sounds like a head gasket issue, but an oil change should not have caused that. Often times when a head gasket goes bad, coolant will enter the combustion chamber. When that happens, the engine will emit a white/grayish exhaust. Take a look at this link that shows how to check for a bad head gasket. Check what it says and let me know what you find.
Also, here is a link that describes what I mentioned and shows pictures of it happening. Read through it, too.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Aug 18, 2018 at 11:46 AM
