Car won’t shift in any gear?
110,000 MILES • 1.5L • 4WD • MANUAL
RICKY BRYANT
Car won’t shift in any gear.
Car won’t start without a jump.
Battery is being drained by something.
Sep 6, 2026 at 12:56 PM
  • 55,851 POSTS
I would remove the battery and have it tested, if the battery is bad/shorted this is your problem.
The correct diagnostic order is:
1. Fully charge and load-test the 12-volt battery. Jump-starting alone does not restore a deeply discharged or internally damaged battery.
Do not repeatedly jump-start it and attempt to force the shifter. Connecting or disconnecting jumper cables incorrectly can damage sensitive modules. If it must be moved, use the manufacturer’s manual park-release/towing procedure and have it transported on a flatbed, especially if it is AWD. Let me know.
Sep 7, 2026 at 9:46 AM
