code p1401
132,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
DWEB
reads code p1401. when driving does not have any power.
Jun 13, 2016 at 7:30 AM
HMAC300
  • 48,601 POSTS
see pics this may be an EGR problem so you will need a vacuum pump like a mity vac and a voltmeter to test. also check for a vacuum leak.
Jun 13, 2016 at 8:21 AM
I am attaching the testing that we need to run through in order to figure out this testing.
Plus here is a guide that will help with figuring this out:
Lets run through this testing and go from there. Thanks
Dec 14, 2020 at 8:09 AM
JCHERRY
I have codes P1401 and P1400 and I'm looking for a troubleshooting tips. Please help. thanks
Dec 15, 2020 at 2:17 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
replace EGR position sensor
(Check for exhaust leak
check the DPFE lines
replace DPFE sensor )
CHELLA209360
did that fix your car?? what did you have to replace?? im having the same problem with my ford escape
DROMERO1977
I have a Ford Explorer 2002 and it looks that code P1401 needs to get fix, Is this an easy fix, and can i buy these parts at a part store or just the dealer?
Also it shows P0125 what's this means?
How can this 2 codes be fixed?
Thank you very much.
Diane.
  • 110,251 POSTS
PO 1401 Passanger side downstream O2 sensor. It is a part that you can unblot and replace by rebolting the new one.
PO125
That indicates the coolant isn't reaching operating temperature. I would replace the thermostat.That is the most common cause for that code.
