Flashing oil warning light
300,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
ZOYISILE GCILITSHANA
My oil warning light flashing and got the oil pump and switch replaced, but the oil light is still flashing.
Nov 5, 2020 at 10:41 AM
We need to start with checking the actual oil pressure with a mechanical gauge because I suspect you still have low pressure if the sensor and pump are new. If you do then that means you have excessive clearance in the engine which means it needs to be replaced or rebuilt.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
However, if the actual oil pressure with a gauge is ok then we have an electrical issue so we need to start with this. Thanks
Nov 5, 2020 at 10:20 PM
Thanks.
Nov 6, 2020 at 5:00 AM
You are welcome. Let us know how you make out and we can go from there. Thanks
Nov 6, 2020 at 6:33 AM
