My oil warning light flashing and got the oil pump and switch replaced, but the oil light is still flashing.
Nov 5, 2020 at 6:41 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
AUTOMOTIVE REPAIR CONTRIBUTOR
We need to start with checking the actual oil pressure with a mechanical gauge because I suspect you still have low pressure if the sensor and pump are new. If you do then that means you have excessive clearance in the engine which means it needs to be replaced or rebuilt.
